Starter Brushes going bad?
mattzmojo
I have a prestolite starter on my 50 hp 1972 motor. My connections are good and the battery has tested fine. I think that I need to replace the brushes on the starter because when I turn the key I hear the solenoid click and the starter does nothing until I tap it with hammer a few times.
Are there any suggestions on any other parts that I should look into replacing on it? Any suggestions on good pricing on parts for my starter?
Thanks in advance,
Matt
HighTrim
Re: Starter Brushes going bad?
Im sure brushes and a good cleaning/lubing will fix her up.
steelespike
The contacts in the relay may be worn you might try tapping on the relay.At 40 years both parts may be suspect.
Will Bark
Tapping on the starter indicates brushes worn out; you can get good prices on brushes/repair kits right at iboats along with good delivery.
mattzmojo
Thanks everyone, I will be buying brushes. I know the starter solenoid (relay)Is good.
