Recently picked up a 1999 20hp merc ob and the lower unit was removed. The cooling tube (from the water pump to the power head) had been removed. One end of the tube is flared and one end is just a straight tube and I am not sure which end goes fits into the power head side. The manual I have does not show that in detail. I did put it together with the flared end into the water pump and someone told me that it should be the other way. I ran the boat after and water did not pee out during idle but had a great, but intermittent flow while it ran at a higher speed. I beleive this motor has a thermostat and not sure if water should pee out all the time or only when the thermostat opens. Any help would be appreciated.
