richluke14
- Nov 29, 2012
- 8
Hi all, I having a bit of an issue with a v6 I am rebuilding. It was originally launched in surf and filled with water so engine was full of salt water causing the engine to lock. Iv stripped and rebuild the engine, heads ect. off sump off pistons & crank out. I cleaned everything honed the bores, and rebuilt. I used the clymer mercruiser book for all torque setting ect. so all should be correct. Spinning it with the starter (no plugs in) it seems tight. Did a compression test and Iv got no compression on all cylinders except cylinder 4 which goes upto around 50 psi but goes tight and slows to almost stopping on each rotation at a certain point. Anyone got any ideas?
Also I should add that the engine was rebuilt a year ago and has been in dry storage since! Thanks in advance!......:joyous:
