Re: Water Pump working properly on 1963 Evinrude 10 hp
In a light weight jon boat with just you on board, you can expect somewhere around +/-15 mph, but that will drop as you add people and gear. You might be able to get up to 20 mph on a very small, light weight boat like a 10'-12' skiff, or Gheenoe. You'll also have to experiment with the best trim/tilt setting, motor height and where you sit in the boat. OMC motors of this era has sort of an odd leg length of 18", so they tend to cause a bit of excess drag when mounted on a standard 15" transom. However, you can simply clamp the motor higher on the transom and/or build a small transom riser, which is what I did. You want the anti-vent plate, found just above the propeller, to be level, or slightly higher than the keel (bottom) of the boat. I also use a PVC tiller extender which allows me to stand while underway as well as shift my weight around in the boat to get the best performance. Unfortunately, there's no magic formula, you just have to do lots of trial and error until you get your rig dialed in. Good luck. Keep us posted. We love pics
