Power Trim
Red1987
When I push my power trim switch I can hear it click in the motor but nothing happens.What come be wrong?
Capt Ken
Re: Power Trim
Normally a click when you push either the up or down button means the trim motor is kaput. But being you haven't a model number or anything, can't say much more.
RRitt
Re: Power Trim
could be a lot of things. make life simple. hot wire the motor directly to a lawnmower battery. if trim works then it's your solenoid wiring somewhere (could be any of three or four things). if trim doesn't work then its your motor.
Dave1027
Re: Power Trim
How about use the boat battery? Around these parts (the low rent district) lawn mowers don't have batteries. :facepalm:
RRitt
Re: Power Trim
car battery, boat battery, etc etc. Heck, a pair of jumper cables off the pick-up works just fine too. It needs to be a good healthy battery though. These trim motors don't tolerate weak or old batteries very well. They often give false symptoms if the juice is low.
aussieflash
Re: Power Trim
Also disconnect all solenoid wires and clean connections till shiny then snug them up tight....Worked for me.
