I have just removed an MC-1 transom plate and I'm replacing in with an Alpha GenII transom plate. The mounting holes and hole required are different. Is there somewhere that has a template for the holes required to fit the drives so I can work out exactly how to do this. I'm sure this must be easily available on line, I'm just looking in the wrong place. I want to print off a full sized template to mount on the boat to mark out all the required holes and material to be removed.
