The whole story. I purchased a lowe pontoon with this motor, put it in the water the first time and did not realize that the water pump was out (didn't know anything about boat motors at the time). The engine overheated of course. We had the pump and heat sensors replaced. Currently I get good flow from the pee line and the boat will idle and move off the trailer and to the dock. However, once on board and under way, after about three minutes the hot alarm sounds. I can shut down, let it cool off and then go back toward the dock, about three minutes, and sure enough I will get it again. Still appears to have good water flow. I have been told that it could be the VRO isn't working correctly and I intend to bypass that if I can figure out how, to test that theory. Any other ideas or thoughts on what could be the cause of the problem?
Thanks,
CDBird
Thanks,
CDBird
