Trying to shorten a 1986 28spl
59texasmaid
I have two motors a 72 -25 hp and a 1986 28 spl trying to use drive shaft from 25 and use on 28 need advise.
ondarvr
Re: Trying to shorten a 1986 28spl
Pull them out, if they look the same go for it.
oldman570
The driveshafts are probbly not the same as is the shift linkage. It can be done but several things will need to be changed and without proper tools and gauges would not last very long. The 72 LU setup was changed in 77 and again in 84. your best bet is to get a driveshaft that is made for the motor being repaired. Check out the stickys on here for salavage yards that might have a shaft you need. JMO
Oldmsn570
Faztbullet
Dont waste your time as splines are different as are water pump,housing and key.
