greendrake
- Nov 25, 2012
- 5
I have had some problems with this motor as I just bought it. I took apart the carbs and cleaned them as the bottom one was leaking fuel and the motor wouldn't start. I had also replaced all of the fuel lines because they were leaking fuel. The problem I'm having now is that the top two cylinders are not getting fuel. The motor starts instantly when I hit the ignition so I didn't think there was a problem until I took the top two spark plug wires off and it does the same. And then when I put them back on and take the bottom two off it doesn't start. Any ideas?
The other problem I have is with the electric starter. It works fine when I do not give it any throttle, but when I give around 1/2-full throttle the starter will run and then it drops down off of the fly wheel. Does anyone know what could cause this?
Thanks.
Thanks.
