I have a 1977 70hp that i have rebuilt and am yet to have running in the water.
I have covered the basics and am now struggling. Carbis rebuilt, 100psi compression. I have spark jumping a 7/16 gap, but looks weak. Video below.
1977 70hp Johnson weak spark - YouTube
The motor is fitted to a later model 1983-1984 midsection with internal trim/tilt. This midsection has a longer exhaust tube runner with seven relief holes in the inner exhaust tube.
The original 1977 70hp had a shorter exhaust tube with only 1 relief hole in the inner exhaust tube, as the pictures show below. The exhaust gas wouldnt have had to pass through water to reach the 2 external reliefs at all.
http://i1200.photobucket.com/albums/bb329/new2boat/IMG_0800.jpg
http://i1200.photobucket.com/albums/bb329/new2boat/IMG_0802.jpg
And this is the longer tube on the 83-84 midsection which is fitted. It doesnt really look like an original tube like in the parts manual so if you have any ideas let me know.
http://i1200.photobucket.com/albums/bb329/new2boat/IMG_0806.jpg
The only way i can see the later midsection affecting idle, is if the water level reaches the bottom of the longer exhaust tube, and creates more backpressure. Meaning the water has to escape through the water to reach the external reliefs.
It runs fine on muffs but dies in the water at idle and when gear is engaged. Carbis have been rebuilt properly and welch plugs removed.
It looks like in 1979 they changed to the longer exhaust tube, and at the same time the carbis changed to the type with the adjustable jet.
Im tossing up wether to change the adapter plate over, or would i be waisting my time.
Or can i fit 1980-1985 carbis? as those motors are still 49ci?
Pulling my hair out on this one!
