bulb wont get hard, fuel leaks out my carb vent
brtc
I cant get my bulb to stay hard before fuel ends up coming out my vent hole on the top of my carb. I tried taking it apart and seeing what the problem was. Does anybody have information on how to properly seat the needle?
HighTrim
Re: bulb wont get hard, fuel leaks out my carb vent
You have it, the needle is not seating.
This is due to either debris in the seat, worn needle/seat, improper float setting, float no longer floating
What motor are we taking about here.
brtc
Thanks for the help. It is a 69 johnson 9.5. My float is worn, the needle looks good and I cleaned the valve port, but I'm going to get a new kit and rebuild it, Thank you. One more question. Regaurdless of the needle being good or bad, can fuel be forced out the vent from squeezing the primer to hard. I'm just curious if i might be "overpriming" or if that's at all possible. Thanks again.
HighTrim
Well, if the needle isnt "seating" properly, then yes you can get fuel out of the vent hole. If it is seating properly, it will never get to it.
That being said, you dont want to squeeze the stuffing out of that primer bulb, lol. A few light squeezes until you feel the needle seat is all that is required.
brtc
Great, thanks for the help. I'll rebuilt it then.
wanty9999
i just rebuilt mine, and am having this problem (48 rude). So if i need to prevent this flooding should i bend the float tab so that the float is no longer parallel to the gasket, and actually a little outwards?
tips appreciated.
HighTrim
I set all my floats so that the unhinged end is just slightly higher than the hinged side. Ensures the needle seats when the bowl is full.
You may also have debris in the seat, preventing the needle from seating properly.
tomhath
Master Chief Petty Officer
It should seal with the float at the specified height. The first thing I'd try is to take the bowl off the carb and hold the float up while you squeeze the bulb. If any gas dribbles down your finger then no float adjustment will make it seal. The needle or seat might have some dirt that's preventing it from sealing. Soak for a couple of days in lacquer thinner and carefully clean it out with a toothpick and inspect for damage; someone might have tried to unplug it with a piece of wire and damaged it. Also make sure you have the float right side up, it's easy to put in upside down (trust me on that).
wanty9999
Well taking them apart again I'll definitely get better at it! Also, it's all new floats, needle and seat so hopefully nO more dirt got in there
Silvertip
Replacing needle and seat may still not solve the problem is you don't adjust the float propery. Setting the float wrong can result in fuel level roo low or too high. That's why there is a spec for float level.
brtc
Rebuilt my carb today and the motor is running great. Thanks for the help everybody.
wanty9999
the float level spec has quite a high range for my 48 evinrude (28-41mm) which is why i was baffled that i couldnt get it right! i mean, this is a very easy task. As it turns out, my fuel lines were connected to the tops of my carbs! I just re-connected the same was as previous owner had done it using photos i took! wowzers! running like a champ now :D
HighTrim
Yeah it is not rocket science. I have never used a gauge or measurement, only by eye. Just ensure it is square, not cockeyed, and parallel to the mounting surface. As stated, I just slightly leave the unhinged end higher to ensure the needle seats. Other than that, easy breezy.
