1978 28'Carver Santa cruz crack in the hull
d04pyma
Hello ! I have a crack in my hull,when they set on the blocks they didn't do it right. Well anyway I have a crack about 6" from the keel the end grain balsa seperated from the outside of the hull a section has concaved in about a half inch.
My question is on the portion that shows a crack line and not through the hull do I cut it out or do I put a groove in it and fill with epoxy then laminate over it for the repair.Also I have the inner laminate removed of the core do I use divinicell or marine plywood, any help would be helpfull
Bifflefan
Re: 1978 28'Carver Santa cruz crack in the hull
I would post these questions in the resto area. You have a much better shot at getting the right answer from those guys.
smokeonthewater
just hold on, a mod will move it there soon enough
