ajax5240
- Aug 6, 2011
- 134
I have a 1984 Bayliner Capri 16'er with an AQ125A I/O and the 270 Outdrive. Starts and runs terrific, have fixed all the wonderful cooling issues, full tune up, good compression, timing and dwell set, etc.
When we use the engine to troll, keeping the RPM's @ 1000 for over 30min it starts to load up and you have to pull all the lines in and run the snot out of it to clear it out. Sometimes will be only firing on a few cylinders till it clears out. Normally takes a few minutes then all is good for another pass.
Anyone have an idea of something I am missing? Or is this old girl just not destined to troll?
Thanks in advance for any help!
