G.A.Miller
- Nov 20, 2012
- 2
I have a 2001 Falcon Striper Delux 23ft. boat, Mercruiser 350mag with bravo outdrive. Replaced the short block in 2006 from mercruy. The ORIGINAL engine serial number is omo70241, model no. 4442067N1, 300 H.P. 5.7 litre
When ideling at low speeds (1000 rpms) often the motor will rev up to a very fast idel, so fast I can't shift to neutrel. I kill the engine, restart, and it usually will begin to idel down. It may run fine several times, then the same thing will happen again. Sometimes it will also sputter and seem to miss at low rpms (doesn't happen often, though).
I have cleaned the breather and wiped out the throttle body, and that seemed to help for a few weeks. But now it is doing the same thing again.
Do you have any ideas that I might try before taking it in to a repair shop?
