Trying to set the timing on a 1998 Merc 5.7 with a 2 barral carb. The serial # is 0L019480. I know I need to set it in base mode, [ground out the purple and white wire] however when I do that, I do not really see a change in the timing or RPM at idle. Should I? Also, this engine has a plastic timing chain cover, with just one timing mark on the cover. I assume this is right at TDC or "zero" ? My merc manual says it should be timed at 10 degrees BTDC. How does one do this without having the timing marks on the timing chain cover?
Thanks for your help!
