50tleds 0324852 retaining screw & seal
flyreels
Hi I have replaced the gear case oil but it weeps from around this screw, on my 50TLEDS 0324852 RETAINING SCREW & SEAL, can I undo it and replace without doing any damage? I have heard about the shift screw and do not want to undo it if it dose something drastic like that.
Thanks Peter
flyreels
Re: 50tleds 0324852 retaining screw & seal
Hi I really need help with this, does any one know what it does? its the Philips head screw closest to the back of the water intake.
Thanks Peter
Will Bark
If it is a philips head screw that should be the pivot pin which attaches to the clutch dog and should be left alone; as far as gear oil leaking out by that screw someone else will have to answer that. If you remove that screw you will be in for some fun getting it lined back up so you can go from forward to reverse.
F_R
flyreel, if you are talking about the screw by the water intake, I believe that one holds the pinion bearing in place. I gotta admit I'm not an authority on this particular year/unit, but I believe it is ok to take that screw out and replace the o-ring without any calamity happening. Better wait for confirmation by some one who knows for sure though.
boobie
Could you post a pic of the screw you're talking about ??
flyreels
Try again
boobie
That looks like the screw that holds the pinion brg in and you should be able to remove and reseal that one. Don't remove the other lower screw as that holds the shift linkage.
flyreels
Thanks for your reply and help.
Cheers Peter
