I have a 2 1996 Mercruiser 4.3 EFI in a 26.footer. One engine runs fine, but the other has just refused to start.
I know it is a fuel issue as it runs briefly with a little fuel pured into the throttle body. The fuel pump runs for a few seconds when the key is turned to start and it is receiving power whilst the engine is cranking.
I have installed a new, full of fuel, filter. This dud engin'e fuel pump sounds slightly different to the good engine.
I disconnected both lines from the fuel filter and the line into the throttle body. The level of fuel in the suction line did not drop and nothing came out of the throttle body connection.
I guess the pump has had an impeller/gear failure.
Has anybody else experienced a pump that runs but doesm't pump?
