marksully1
- Aug 11, 2012
- 3
I have a 1978 small block chevy 305 with a Rochester 4 barrel, the boat was laid up for a long time. When I got it I had a guy look at the engine, I had to get the crankshaft reground with new bearings, new oil pump. The engine now runs well, starts fine, but I have to adjust the idle high to stop it cutting out when I shift. I have try'd a new shift interrupt switch also a carb clean and new gaskets new water filter . The carb had signs of water inside. The boat is hard to control as it moves to fast in gear at low revs. I have to idle at around 1100 rpm, I think it should be 700. If I set the idle at 700 it cuts out when shifting. I have tuned the carb also checked timing. Any suggestions ?
