rspeerbrecher
- Jun 19, 2006
- 2
i have a 1981 sea sprite with a GM 3.8 v6 and an OMC Cobra (400? i think) outdrive. The trim doesn't work, now. It worked when i bought the boat, and right before i went to take it out, (on a checklist of things) discovered the outdrive would tilt but not "high tilt" i just get CLICK CLICK so we checked the celenoids with a multi meter and found the bad one and went to replace it, after that, nothing happened, no click no soundz and the motor won't even crank i think i got the wires messed around because i had to take the original with me to match it up and the wires were just left there hanging, there are 5 celenoids on top of the motor up dwn trim up dwn high tilt and i have no clue what the 5th is? I was wondering if anyone could help me with a lay out of these wires which is what and where they go? thank you, any help is appreciated! <br />~Russ
