F225 tilt trim sticks in down with pump running
davidgin
2002 f225 when I trim down the pump motor continues to run and the only way to stop it is to switch off the battery. After I turn the battery back on it works ok. I assume the relay contact stuck, where is the relay and is it just a plug in type.
Capt Ken
Re: F225 tilt trim sticks in down with pump running
Try unplugging the switch on the engine and trying again. I've not had the relays do that before but have had the switches act that way.
