50hp Evinrude Outboard G3659167
zamgod
Can anyone please tell me the age of my Evinrude?
The only number visible on the engine is G3659167.
It doesn't look like the proper Evinrude format, but there is nothing else to go by.
Thanks.
boobie
Re: 50hp Evinrude Outboard G3659167
From what I can find out it's a E50RNLIC. 1994 military or commercial.
Post a pic of it if you can.
zamgod
Thanks for the information, here are some photos.
I can get more if necessary.
boobie
Are you sure there's not some #'s on the stern brackets ?? The guy I got the info from may have been wrong. Maybe somebody will chime in with better info.
zamgod
I'm positive that there are no numbers on the stern bracket and there are no visible signs of any plate being removed.
The engine is two cylinders and has tilt/trim.
I'll take some photos under the cover, that might help, if it stops raining long enough.
You could be right though, I bought the boat c/w engine from a coastguard here in Scotland. So the engine could be ex-RNLI.
One of my fishing buddies has a similar coloured engine and his is 1992. So I'm hoping your assessment is correct.
Thanks.
boobie
Hopefully I can talk to a different guy this week and if I get more info I'll let you know. Is that the number on the quarter size plug on the block and is it correct ??
zamgod
Yes that's the number on the aluminium plug on the block.
I've taken some photos under the cover, so here goes......
zamgod
And some more.....
Bye the way, many thanks for your help.
zamgod
Hi,
I've got a list of part numbers on the engine, those that I can see. Maybe that will help.
Power Pack : CD2SL / 585074 9A T-OA
Siemens Relays (2) : 9902 586224 VF4 15F21 211
Single Dual Ignition Coil : 583740 24AT - OA
Inline Fuse (Relay) 514491 (2 wires; 1 to loom and 1 to relay holder)
Spark Plugs : Champion QL16V
Head Casting : 334280
I don't know if this is much help or not?
zamgod
Did you manage to glean any information from the "other" guy?
Thanks.
