Hello, I just purchased a 1988 sunray continental with a 3.0 omc motor and it had a 3.0 omc cobra outdrive that was stolen. I found a 2.3 outdrive for a killer deal and picked it up all the seals are good oil was nice and clean and no metal deposits were found in gear oil. Now I found out that the 3.0 outdrive is a 1.71 gear ratio and the 2.3 is 2.00 I found out that I will be loosing 7 mph but will it cause any other ill effect on the motor or outdrive if they are mated together.
Thank you
Gabriel Bergeron
Thank you
Gabriel Bergeron
