just want to add this was a brand new motor with maybe 10 hrs on it. Totally my fault, I'm an idiot, I KNOW. Took it out for its first run and noticed when i took the engine cover off I could hear trickling of water coming from what I assume is one of the bellows. Didn't have time to pull it out of the water before wife had to be to work so thought it would be fine overnight. I ran the bildge pump before I went to bed(not an auto bildge). Woke up to the 2/3rds of my boat under water. Immediately got to pulling it up. So far, drained the oil and refilled it, pulled plugs turned the motor over for about 10 minutes, drained fuel from carb (tryingto run it off a gas can). Can't get fire..... replaced coil(have 12 v a + terminal), distributor sensor( have 12v on red and white), and amplifier still no spark. Im losing my mind because I know time is of the escence. Any and all help is appreciated . thank you. Went though the ignition trouble shooting process with no luck. Only thing I dont quite understand is "inserting a spark gap" to tap green and white lead on ground. Does this mean just hold the wire a hair off the terminal?
