YamahaF200
- Nov 13, 2012
- 29
Is there an alternative oil to use in the Yamaha F200 Outboard engine? $83 for 6 qts of oil and filter seem steep.
thx in advance
thx in advance
Yamaha 4M lists for $8 a quart so that is $48. Can't remember how much the filter is but it isn't $34. Buy two gallons jugs next time and save a half gallon for the next change. Gallons are cheaper.
Sure most any 12 Volt hours meter will work also Yamaha sells an hours meter with an internal battery and wire that attaches to a plug wire it works good but needs to be located inside the engine cowling. You might want to consider getting the YDS software and cable assembly that way you will know exactly how many hours at what RPM the engine has. You can get the interface cable off Ebay and the software is available many places.
