69 Alumacraft
- Nov 15, 2009
- 173
The issues started when I could hear a faint clicking noise if I spun the prop by hand when it was in neutral. If I moved the shifter back in forth with the engine off and then put it back in neutral the prop would spin freely without any click. It seems to have gotten worse as it does not always like to shift into reverse where it used to and I have to push the throttle back further to get it to shift. No problem shifting into forward. I attempted to adjust the cables by taking the clamp that hold them in place and adjusting the trunions but could not get the problem to go away. My question is: ? Are my cables junk or do I need to completely disconnect them from the motor while it is in neutral and then start adjusting? I have read the top secret file.
