Folks,
I've fallen heir to a deep/wide 1969 I/O 19ft runabout, which has a DEAD & UNREPAIRABLE 120HP Mercruiser
and
a Model 120/140 Mercruiser outdrive, which is in good shape, currently installed.
I have also found a complete, low-hours, 1985 model, 4-cylinder, Mercruiser 140HP for cheap, that I would like to install in the big runabout.
Does anyone here KNOW if this is a reasonable swap?
(A book from our local public library states that SOME 120 and 140 engines can easily be swapped-out but that others cannot be. - Unfortunately the book doesn't way which will/will not work as direct exchanges.)
I'm hoping that someone here KNOWS for sure what must be done to do this swap, IF it is do-able without spending a pile of money (perhaps) needlessly
OR
If I should seek another engine for the boat?
yours, tex
and
OR
yours, tex
