Re: Winterizing 200Hp Ficht Outboard
Parts will run you about $60. Get a spark plug socket a can of fogging oil and do it yourself.
Very simple to change the filters. They screw off. To get the one in the engine, take the lower cowling off on that side then the filter just unscrews and drops right down. There's a probe that comes down into the filter so be sure to drop the filter completely down to clear this probe.
As for winterizing, put extra stabilizer in your gas, start the motor, let it warm up, remove the plastic cover over the air intakes, spray a 2-3 second burst in each intake, shut motor off, pull each plug and spray a 2-3 second burst in each hole. Crank the engine a few rotations without starting it to get the oil circulated.
Put (old) plugs back in and you're good till spring. In the spring, start it up and let all the crap blow off, then shut it down and replace your plugs.
I also spray my exposed electrical connections with WoodyWax to protect them.
I
