i just recently got my 1st boat..its a 1977 larson 18'<br />with 898 mercruiser type 1 stern..done all my oil changes and plugs stern lube no water..changed it anyway.hooked the muffs up and it started nicely and ran good..thinking i was ready for the water took it out backed it in and a quick fire and it died.tried this several times with the same results..sounded like a car when you flood it.sputtered and die.pulled the cover off and looked around did notice a small drip of water coming from the (what would be exhaust on a car)connected to a big 6-7" round rubber hose leaking right there..would this cause my problem or should i look elswhere.there was no other leaks around the motor.pulled it out of the water,pulled the plugs on the back and side of boat and id say 5-6 gallons of water poured out the back.<br />but there was no water under the engine but the small amount from the hose and exhaust..any ideas or suggestions would be greatly appreciated
