phillnjack2
Ensign
- Apr 30, 2011
- 918
EVINRUDE 1995 60HP 3 CYLINDER
Model no BE60TLEOC.
I am having trouble with getting the battery charging and rev counter working on my engine.
I have tried various rectifiers/regulators etc and i am now wondering if i have a stator problem ???
Today with engine running i put my multi meter on the two (2) yellow wires comming from the stator.
I didnt get anything with the red lead from mulit meter on yellow and black lead from multi meter on
yellow with grey stripe, also tried this the other way round and still nothing.
With the black lead from meter to ground and red lead from meter to yellow i then got exactly 12 volts.
Same with the yellow/grey wire.
Even when throttled up still no gain involtage, the battery is exactly 12 volts as well (i know it needs a charge).
should the 2 yellow wires give a higher voltage than just the same as a low battery ?
is this about correct from a stator or should i have got more voltage from it ?
the engine starts and runs so i assume the stator is giving the cdi unit its currant but just not sending a
charging currant ?
does this sound as if im testing it right ?
i realy am getting fed up with the electrics on this engine, and dont want to be buying stuff for it if its not needed.
please help or tell me what im doing wrong, as i need to get this engine running right, i am fed up with charging
batteries and having to carry them down to the boat.
plus i need the rev counter working obviously .
phill.................
Model no BE60TLEOC.
charging currant ?
