Yamaha 150 2stroke excessive smoke
Nogood82
My 150 smokes bad when trolling or running at low RPM's. If I run it hard for a few seconds it clears up and stays clear until I go back to trolling for a period of time or running slow. Any suggestions?????????????
Georgesalmon
Re: Yamaha 150 2stroke excessive smoke
If you have a VRO system it might to pay to have that looked at by a pro. Could be its sending to much oil out but I don't have a clue how to check that. It actually sounds kind of normal to me.
99yam40
Check to make sure the oil linkage is still attached to throttle linkage.
If it comes off it will go full open and dump too much oil at low RPM
Nogood82
Was looking at it yesterday. I'm a racecar person and I know very little about boats. Where will the linkage be hooked up??
Capt Ken
Bottom carb, port side. Arm that connects the carb linkage to the oil pump. Oil pump has all the little hoses coming out of it like a distributor.
Nogood82
10-4. I'll check in the morning when I get home.
