Re: Over reving a mercury electrical system without a regulator Question
Regulated puts our about 14.5v. Unregulated puts out about 16 volts. You have to have more voltage than is on the battery to cause it to charge. The big factor is the current capacity of your charging circuit and the power usage from your battery.
I think I am correct in stating that the unregulated outputs are from low amperage regulators so even though it has the capacity to put out 16v basically unloaded, it doesn't do all that much to overcharge your battery. If you are concerned about it just feel your battery and if unsealed look at the top near the caps. If overcharging, it will be warm to hot to the touch and you will see fluid residue around the edges of the caps.
From my OEM Merc manual, for a manual start outboard in the 75 to 125 hp category (my manual covers these engines), late '90's production, a 9 ampere alternator, with optional rectifier is rated at 0 amperes at idle up to 10.5 amperes at 5000 rpm. It says that the basic engine voltage output, unrectified, is to operate running lights only. Soooo if you ran at WOT for extended periods of time and started the engine rarely, had a full battery to start with, and had no electronics or lights to consume energy stored in the battery, looks like you might be able to over charge it. I'd assume that on a smaller engine, like a little 9.9 hp fishing motor it would be significantly less. If for no other reason, the space under the flywheel would be much smaller and thus no room for the alternator to be very large.
Oh, it's the amperage that charges the battery. The voltage just pushes the amperage and the battery charge level vs the applied voltage and current capacity with the load on the circuit at the time set the charge rate.
HTH,
Mark
