Re: '84 50 hp 4cyl Is electrical system regulated?
So I have two questions:
1) was this system designed as an unregulated system?
2) if yes, is 17.4VDC to be expected from a healthy charging system for this year engine.
1) Yes.....
2) Yes and No as you are overcharging. Your engine has a 6 amp system at thats at WOT. You dont mention in your post as the type of battery you have but always use a non maintenance free battery with a minimum of 700 CCA. Maintenance-free batteries (gel cells / AGM / closed-case) have thin plates. They’re ideal for a charging system that maintains a typical charge between 12.5V – 14.4V, but not for outboards, where batteries are commonly drained by accessories i.e. when there is no charge applied to a battery while the battery is in use. The thin plates cannot withstand constant discharging and charging. It will develop weak and/or dead cells due to this
behavior. Its heavy plates can withstand constant discharging and charging. These batteries have much more reserve time and are much more suited for this behavior Here is a list of do and dont for these systems:
1) recommended type of battery for outboards is a single (NOT more than one) 700+ CCA dual purpose or cranking/starting non-maintenance-free battery.
2) NEVER allow the stator to charge a battery. The stator is designed to maintain the battery's voltage at an
optimum charge. It's not designed to charge a dead or weak battery
3) NEVER jump-start a battery while an outboard engine is running. This can cause damage to the rectifier
4) A rectifier’s job is to convert the stator’s AC signal into DC to charge the battery. In non-regulated applications
(rectifier only), the battery acts as its own regulator, which is not designed to do. When it can no longer self-regulate
proper voltage from the rectifier, usually due to dead and/or weak cells, it poses a serious threat to rectifier failure
and thus needs replacing.
5) Check all battery connections, particularly at engine ground. Make sure all connections are corrosion-free and tight. Do NOT use wing nuts. They will loosen over time due to vibration, causing battery and/or rectifier/regulator failures.
In your case since its overcharging this is what I would look for in this order: 1) connections 2) battery type/condition 3) stator. Measure DVA voltage across the stator's battery charge wires (typically Yellow wires) while connected to the rectifier. At idle, DVA should be between 17-25V DVA. If not, disconnect the yellow wires from the rectifier and retest for 17-50V DVA at idle. If not, the stator is possibly faulty.Also the check the DVA voltage from each battery charge wire (typically Yellow wire@1500 rpm)) to engine ground. The two readings must be within 1.5 volts of each other (i.e. if one is reading 20 volts, the other has to read between 18.5 and 21.5 volts). If the readings are not equal,place a mark across the connection between the stator and rectifier that measured low. Turn the engine off and swap the stator leads. Crank the engine up and retest. If same results the component that has the marked wire with the low reading is bad.....
