glenn property of pam
- Feb 17, 2012
- 2,906
my controller never had a kill/lanyard switch so after buying one and leaving it on the counter for 6 months i got around to installing it. now i was sure that M to M was n/c with the lanyard removed and open with the lanyard in place but on the one i bought it is the other way around and C to C is closed when the lanyard is removed and open when its installed.
i must admit i dont normally check the letters as i prefer to check everything with a meter to be sure but i was sure that it was meant to be the other way around. i tested the lanyard and it cuts the motor when removed so its working so either im wrong or the switch was marked wrong (outboard 120hp evinrude)
