View attachment 174373View attachment 174374
I have attached two pictures of my fuel tank showing the pickup tube. The metal fitting screwed out leaving the plastic tube in the fitting. The plastic tube will not come out completely. When I unscrewed the fitting there appeared to be a crystalized resedue on the threads and nipple. It appears that the pickup tube is permanent. The tank has set up for several years. Some fuel was inside the tank when I could not get a prime, I replaced the siphon bulb but could not get a prime. The tube may not keep a prime. The tank is made by Inca, 12 gal, tank type is F02012, made in 1989.
