motor losing prime
I have 1989 johnson 88hp v4 new carbs, fuel pump and fuel lines. Will run on 6 gallon remote tank but not on built in tank (new pickup tube and sending unit). Thanks for any help
boobie
Re: motor losing prime
Have you checked the anti-syphon valve in the fuel line connector on the built in tank ??
emdsapmgr
Have you checked to be sure that the vent on the built-in tank is open/unobstructed? Same fuel line?
Georgesalmon
I hesitate to say this because it can be very unsafe, but,,,,,,,,,,,,,,back in the day I remember that there were some outboard engines that could not overcome the anti syphon valve. I even remember (I think) that there were some made differently for I/O engines and outboards. You might try using a hose barb in place of the anti syphon valve and test it. If it works then I would look for a different brand valve. I would never suggest that you leave the anti syphon valve out of the fuel system for normal operation.
Edit: You do have a bulb on the remote tank fuel line and have pumped the fuel till firm right ?
Rmoore45
I had a similar problem with my 9.8 merc, I could prime it and it would run for a while but once I got going wide open it would starve for fuel and die. I found a small leak in one of my hoses which allowed the fuel pump to suck air and not fuel. I replaced the line and it solved the problem.
emdsapmgr
Just to be clear, you are using the same fuel line when testing both tanks. With the tank end connector when you run on the 6 gallon tank, then you remove that tank end fitting and install it on the anti-siphon valve hose barb on the built-in tank. Correct? What happens if you install the hose on the built-in tank, then remove the engine end fuel fitting-then prime the hose bulb. You get plenty of fuel gushing out the engine end of the hose?
emdsapmgr
The 6 gallon tanks don't have an anti-siphon valve. Your built in tank does. You could do another test of that valve. Either replace it with a regular (straight through) hose barb, or you could remove the retainer, ball and spring from your current anti-siphon valve. Same thing. See what happens.
removed retainer, ball and spring from valve today with no luck. Still losing prime. Thanks for sugestion
Outsider
Blow through the fuel line into the tank. If it's clear, you have a fuel pump issue ...
FWIW, anti-siphon valve isn't required unless your fuel tank/line are above the carbs ...
