Re: 470 head bolts
You can call ARP and see if they can make something up. BB 385 series Ford bolts or studs may work on the 224 as that is the cyl head they use, but you will end up with double the needed bolts. In any case, new 3.7L/224 head bolt sets are readily available and pretty cheap, so it wouldn't make sense to reuse old bolts
