115hp mercury
- Nov 7, 2012
- 7
Hi there,
I have just done a full go over of my 115hp mercury blueband motor. Taken all 3 carbies off and fully dismantled and cleaned, renewed all fuel lines, new water pump, new plugs. When i started it there was water seeping through the 2nd and 3rd spark plug as well as a little hole net to the top spark plug. Before this my tell tale water lines was blocked at outlet so i unblocked it and then had a stream flowing. Also had water coming out of the exhaust vents. Why is this happening.Is it something to do with when i put the bottom leg back on after installing the water pump and maybe misallingning when put together. IT never use to leak water from the spark plugs?????????
Any answers?
Thanks
Glenn
Any answers?
Thanks
Glenn
