garyplotner
- Nov 5, 2012
- 20
Hello All
I'm in the process of installing new SL3 controls so that I can have some throttle control during cold start ups.
I believe I have 33C cables and so I'm using the recommended holes on the levers. Now the real problem. Using the mercruser manual, I'm not making any progress in getting the shift cable to travel the distance to shift the drive from forward to reverse and back. My shift cable does not have the brass barrel shone in the manual, but instead i have a plastic holding connection. The only way I have been able to get the shift travel range is to move Stud (B) from its bottom location. It seems that the amount of travel to shift the drive from forward to reverse required more travel than me cable is providing. I know I'm missing something.
I haven't even gotten to the cutout switch adjustment. But from what I can see at this point, the roller is not staying in the neutral position.
thanks for any help
Cheers Gary
thanks for any help
Cheers Gary
