Re: OMC cobra trim limit.
Update: Don I just talked to a friend that I bought the boat from 8 years ago. he bought the boat new in '87 and he said that it never had a trim limit. That just floors me, I can't believe that OMC would not have a way to keep a newbie from trashing a lower unit. sorry to waste your time, but thanks for your reply.
Trim is not something you set to a point and never touch it again, you constantly have to adjust due to waves, wind, boat loading, weight, rpm, etc.
It's very simple, if the engine rpm's start going up and the speed goes down, you are trimmed to high. Put the drive back down in the water.
If the engine rpm starts going down, and the speed also goes down, you are trimmed to low, and the bow of the boat is blowing through the water not planing. Lift the drive up.
You trim the drive so you get the highest speed and highest rpm. If the boat starts porpoising (Bow bouncing up and down) you are again a little bit too high.
With experience, you will be able to hear and feel the differences and the adjustments will become second nature.
