  #1
Old April 8th, 2004, 01:42 PM
shorty28 shorty28 is offline
Default Need Opinion For New Decking Pontoon
After lots of reading and asking questions, I think I have decided to redeck my pontoon with non-treated exterior plywood. I also plan to coat both sides with epoxy resin...but no cloth. Does anybody see any red flags with this method. Would anyone recommend not putting resin on the bottom so the floor can breath?? Thanks
  #2
Old April 8th, 2004, 02:09 PM
G DANE G DANE is offline
Default Re: Need Opinion For New Decking Pontoon
If you coat plywood with resin without cloth you might as well paint it. I really think paint would hold up better as resing used as paint, as resin tends to develop small cracks that will allow water to get in, but very slowly escape again.
  #3
Old April 8th, 2004, 02:32 PM
jtexas's Avatar
jtexas jtexas is offline
Here's a tip I got from West Marine the other day: if you're using fasteners on your floor, drill the holes oversize, fill 'em in with epoxy resin, then drill holes for your bolts in the resin - eliminates a source of water penetration into your floor.They also said that heating the wood up to 125 to 150 degrees with a heat gun after painting on the resin would speed up absorbtion and also cause it to absorb more resin more deeply.
__________________
"It's all about the tools." -- myself
"Poets talk about 'spots of time,' but it is really fishermen who experience eternity compressed into a moment. No one can tell what a spot of time is until suddenly the whole world is a fish and the fish is gone. I shall remember that son of a b**** forever." -- N. Maclean
  #4
Old April 8th, 2004, 02:33 PM
Thanks for the heads up, I assumed the cloth was for strength only. With my pontoon, the 3/4"ply screwed to 12" aluminum centers doesn't need much strength. I just want to avoid wood rot. What type of paint would you recommend.
  #5
Old April 8th, 2004, 04:08 PM
pjc's Avatar
pjc pjc is offline
Please consider using CPES, a penetrating epoxy that has an anti fungal (prevents rot) additive. IMO folks who encapsulate any wood in epoxy or other resin have a false sense of security. Moisture trapped in the wood upon encapsulation is just as prone to dry rot at non encapsulated wood. Encapsulation as I understand it is complete. Thus preventing any entrance of "air" oxygen, that is part of dry rot, or, fungal growth, or propagation. Seal 'er up good you may be good to go.Then paint wood with what is recommended by the CPES manufacturer.Just my opinion.Pat
__________________
"88"
  #6
Old April 8th, 2004, 05:52 PM
BillP BillP is offline
Location: Recently moved to high rise waterfront condo on Pluto. What a view!
Why are you not using pt ply? Non treated wood is prone to rot and using coatings to seal is ok until a tiny pinhole gets though and lets water in. I have a 20' pontoon boat and the deck is 3/4" pt ply with carpet glued down over it. It is 8 yrs old and still no rot worries. Check the structural engineering properties of cheap 3/4" pt ply before being worried about voids causing a problem on this application. http://www.apawood.org/
  #7
Old April 18th, 2004, 08:58 AM
beagletracker beagletracker is offline
If you are serious think about adding liquid styrene to the resin. It will cause the resin to soak into the wood. In my opinion it would cause the wood fibers to be much stronger and resistant to rot.
  #8
Old April 18th, 2004, 09:48 AM
Bond-o's Avatar
Bond-o Bond-o is offline
Master Shipwright
I'd use 3/4" Pressure Treated..........It'll Last Longer than You, or the Boat.........I Agree......Coating with Unsupported Resin is a False Security.........
__________________
Any Grease is Better,..... Than No Grease at All.......
NO PM's (Private Messages) regarding boat/engine problems. That is what these forums are for.
They will be Deleted
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
pontoon decking MichaelMullis Boat Restoration and Building 7 August 4th, 2009 03:55 PM
decking for a jon ??? raidercoop Boat Restoration and Building 15 October 6th, 2006 12:21 AM
USING COMPOSITE DECKING TROY MALECKI Boat Restoration and Building 5 March 10th, 2006 01:42 PM
decking ray21 Boat Topics and Questions (not engine topics) 1 April 8th, 2002 01:21 PM
help with wooden decking pls john macadie Boat Topics and Questions (not engine topics) 2 August 27th, 2001 02:21 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
