garyplotner
- Nov 5, 2012
- 20
Hello All
I have a real stickler of a problem. Having read Don S execellant guide for trouble shooting, I thought maybe I had the problem under control. But that is not the case. I assumed that because I had an intermittent starting problem I should replace the 3 position switch. That did not fix the problem. Still no solenoid action when I turn the switch to start. What's interesting, when I touch the "start" wire (Y/R) to the power wire I get a starter engagement. But holding the Red power wire and the purple "Ing" wire together and then touching the start wire, I get no action at all. Really confused. Thank for your help. I'll be out a few hours.
Cheers Gary
Cheers Gary
