torombolo
- Mar 15, 2012
- 151
Morning members!!
I have a MOnterey 262 (2001) with a Mercruiser 5.7 and a Bravo III dual prop. back in june I had to replace the engine coupler that went bad gave the Bravo a rutine maintenance , seals, lube etc. and after that it worked good, I have used the boat only 4 or 5 times since then, the thing is the Bravo is at it AGAIN.
Scenario:
My engine RPM's 3500
GPS Speed 9 mph, tops
No wind, not chiopy either
After noticing the lack of push wend down to 2000 RPM's and back to port
I think there is some play in my props could this be?
Are there any bushings or anything that the props might be slipping?
Thank you in advance for any tips and help.
Scenario:
