I am rebuilding the transom on my 1984 Grumman 5.0. I am using doug fir plywood and am short 1/8 of an inch for the width. Is there any reason not to laminate both sides of the transom with formica. I thought this would make a great water barrier. The transom rests in an aluminun pocket that has no holes for eventual water sepage. I was wondering if it would be worth while to drill holes in this pocket and then scallop the bottom of the transom the let water drain not just sit there. Any thoughts would be apreciated.
Thanks Phil
Thanks Phil
