Hello, I was out on the water yesterday running the boat and just as soon as I was going to put the boat back on the trailer I went to start the motor and the motor wouldnt crank. I took the cover off and the starter where the teeth are suposed to raise to the flywheel spins but dosent actually make contact with the flywheel. (Sorry if I'm not explaining this correctly). My question is, can I fix/adjust this or is it pretty much done for and I have to buy a new one? Nothing looks/sounds broken. By the way the motor is a 40 hp rude 1993; model number TE40ELETB
