On a recently used purchased of 29 foot Powerquest FX, I need some advise how to fix two of my display panels that are used to mount all of my guages and toggle switches. Both aluminum plates are mounted to the fiberglass console with#8 stainless steel flat head screws. The problem is that almost all of the screws that are screwed into the fiberglass console no longer grip into the fiberglass console which is only about 3/8 of an inch thick. All of the holes are oversized and I need to know what I need to do to make the srews have something to grab onto to hold both of these aluminum display panels to the fiberglass consoles. I was thinking of gluing down some plywood to the bottom inside of each console. Just open to any suggestions to fix this problem.
