Hello all,
Forgive the newbie for what may be a very obvious question! I picked up a 1959 Evinrude Lark 35HP a few weeks ago. The seller didn't have a test tank so couldn't see it running but it had spark and pulled over no problem with a solid "thunk-thunk" sound so I figured it had good compression.
I got a fuel hose and tank for it, hooked up the electrical cables and popped her in the tank today to properly winterize.
Now for the confusing bit. The electric start seemed like it was having trouble getting the flywheel to turn over. It would do so, but only one revolution every few seconds and it seemed like it was really trying. Admittedly it wasn't easy pulling it over by hand either but I expected the electric starter to be a bit better at it! I took out the plugs and the starter turned the flywheel much faster.
As for the fuel line, I got it primed, with fuel in the bowl, but when I tried to start it the fuel disappeared and even after squeezing the bulb again it didn't fill the bowl more than a very small amount. I did notice that gas was dripping out of the front of the carb after this...
After a few minutes of trying to start it, I took the plugs out and noticed they were clean and dry... so I wonder if fuel is actually getting to the cylinders at all.
So questions.
Does the temperature outside have anything to do with how easy it is to pull over a 35 HP motor? It was about 4 Celsius today (39 F).
If not, what could cause the flywheel to be so hard to turn? What can be done to fix it?
I tested the compression and leaving one plug in while inserting the tester I got about 60 psi on both cylinders. When I took the other plug out the tester read 125 psi in both cylinders. What causes the difference? Is that a problem?
I have ordered the service manual for my motor so will have that in a week or so and am hoping to be able to rebuild the carb and redo the lower unit seals and impeller since the guy I bought it from said it had been sitting for years after his wife's father stopped using it in the 80s.
Thanks for any thoughts or insights!
So questions.
