cpt chetco
- Nov 3, 2012
- 2
I have a continuing problem with my 71c, behind a Perkins 4-108. The rear seal leaks, even though I have replaced it several times. Also have had the fill/check plug pop out, and the breather leak some fluid (a tblspn). It has not been overfilled.
I wonder if it is running too hot. The engine runs at 195, and the trans cooler is shared with the engine oil cooler to coolant (not raw water).
