Flyin' boats
southkogs
Read THIS article this morning and found it kinda' interesting (figured drone boats were on the way). BUT! In that article there was a link to THIS article ... flyin' Aircraft Carriers!?!
JB
Re: Flyin' boats
Both the Navy and the Army Air Corps built flying aircraft carriers in the 30s-40s.
The Navy version was basically a dirigible and the Air Corps/Air Force version was basically a B-36. Neither worked very well.
64osby
Re: Flyin' boats
I read an article many years ago about a Russian transport plane / boat. It was massive, 3 or 4 times larger than a 747, and sat in the water at low speeds and then flew at 300 mph when out of the water. It didn't fly high, about 100' above the surface. At one point they were looking to use it for commercial ferry service between ports.
CharlieB
Re: Flyin' boats
I don't remember the specifics, but...........
There has been some very large 'objects' that can only fly within a measured distance to the ground because of 'ground effects', the larger air pressure produced between the object and the ground creates enough 'cushion' that the object floats, or has the appearance of flight. Attempts of gaining more altitude loose this air cushion, and the object falls, crashing.
You have seen this ground effect lifting race cars when they get sideways , lifting and blowing the cars over. Boat blow-overs are another example, all is well flying along until a little too much lift, then totally out of control.
southkogs
Re: Flyin' boats
I remember both of those ... the old XF_86 Goblin. Plenty of gags about that goofy thing in USAF lore ;) Though, it did have a certain "cool" factor to it as well. I'm not sure they actually "landed" more than a few of those back on the trapeze, did they?
Totally intrigued me ... if THIS is it, it's a neat idea. I'm not sure she ever got much higher than just at the surface, and I'd sure not wanna' hit any weather in that thing ...
CharlieB
Re: Flyin' boats
Wow, that is exactly the machine I was trying to describe. Land or sea ground effect transport.
64osby
Re: Flyin' boats
That's the type of craft I was thinking of. I might have been off on how high it is off the water.:redface:
Pretty cool stuff. Not very maneuverable. Would hate to be a small craft in its path.:eek:
64osby
Re: Flyin' boats
nwc - That is a cool toy. Bet it is $$$$$
