I have a 1976 35 hp evinrude. I started hearing a sqealing noise when throttling down or up sometimes but always when coming down off a plane. I'm worried it is a bearing sqealing. Now the parts manual shows the oil recirculation hose going from the lower crank bearing to the upper crank bearing, and the other going from the intake manifold to the upper cylinder. My service manual shows it going from the upper crank bearing to the intake manifold, and the other hose swapped as well. Does anybody know the right way to hook them up? I have it hooked up to where the upper and lower crank bearing are hooked together. This does not make sense to me just because i'm thinking about how the pressure would control the oil/gas mixture. To me it would be equal pressures back and forth and the oil would never really keep flowing through the bearings. If anyone could help me that would be great. thanks
