Hi, I had replaced my water pump and some seals in the spring. Had no problem all summer. Recently took boat out of water for the winter and drained lower unit gear oil (blue in color). Nice and clean , no water. Filled back up with new oil(blue). Noticed green oil dripping out of the prop, mostly from chamber around the nut holding prop on. Had used oil that was green 2 years ago. What's going on? Is a prop seal bad?
Thanks, John
Thanks, John
